ARUK
Feb 18, 2019Follower
Netgear ReadyNAS RN212 UPS Options?
Hi,
Please can someone give my advice on UPS options available for the RN 212, I have constant power drops and i'm looking for a safe shutdown option.
ARUK
Feb 18, 2019Guru - Experienced User
schumaku wrote:
In short: Go for an APC UPS.
I don't see many issues posted here on APC UPS. So that is a good choice. FWIW, I use CyberPower, and have no issues with it.
Sandshark
Feb 18, 2019Sensei
While I have no problem with mine, some folks have had issues with certain model Eaton UPS's.
ReadyNAS uses NUT (Network UPS Tools) for UPS You can find their compatibility list here: https://networkupstools.org/stable-hcl.html.
