Alaster
Apr 24, 2025Aspirant
Netgear ReadyNas102 server
i have just purchased a new PC with windows 11 and when setting up access to my ReadyNas 102 server with the use of RAIDar i can see the server harddisk but am unable to Access i believe i have missed...
Sandshark
Apr 24, 2025Sensei
That's not a lot to go on. What method are you using to try to access the NAS? Are you prompted for a user name and password? Do you remember those? What error message(s) are you getting. Does RAIDar show your NAS? Can you open the admin GUI?
Short answer is you do need to give it a user name and password unless you set up the PC with the same name and password, in which case Windows will pass it on to the NAS. But how you do that depends on how you are trying to access the NAS.
