Alaster
Apr 24, 2025Aspirant
Netgear ReadyNas102 server
i have just purchased a new PC with windows 11 and when setting up access to my ReadyNas 102 server with the use of RAIDar i can see the server harddisk but am unable to Access i believe i have missed...
Apr 24, 2025Guru - Experienced User
Sandshark wrote:
That's not a lot to go on. What method are you using to try to access the NAS? Are you prompted for a user name and password? Do you remember those?
Also, if your old PC is still running, can you access the NAS from it?
Alaster
Apr 25, 2025Aspirant
i am using Raidar to access my server and when i installed Raidar it did not ask for name or password just installed to show server disk
