Alaster
Apr 24, 2025Aspirant
Netgear ReadyNas102 server
i have just purchased a new PC with windows 11 and when setting up access to my ReadyNas 102 server with the use of RAIDar i can see the server harddisk but am unable to Access i believe i have missed...
Sandshark
Apr 24, 2025Sensei
That's not a lot to go on. What method are you using to try to access the NAS? Are you prompted for a user name and password? Do you remember those? What error message(s) are you getting. Does RAIDar show your NAS? Can you open the admin GUI?
Short answer is you do need to give it a user name and password unless you set up the PC with the same name and password, in which case Windows will pass it on to the NAS. But how you do that depends on how you are trying to access the NAS.
Alaster
Apr 25, 2025Aspirant
Error message is windows can not access \\ IP Address
- StephenBApr 25, 2025Guru - Experienced User
Check the windows credential manager on the PC that works, and see if there is a credential stored for the NAS there.
Try creating a credential on the new PC for the IP address that uses a username that matches one on fhe NAS. Include the password if you want to automatically connect without needing to enter it.
- SandsharkApr 26, 2025Sensei
RAIDar is not actually used to access the NAS. It's a discovery tool and can launch a web browser for the admin GUI if you select "Admin Page" or Windows Explorer of you select "Browse". Based on your error message, I believe you are doing the latter, so the issue is with Windows Explorer. Please confirm, as that is the direction StephenB is going as well.
You are not prompted for a user name and password when you try this?
Have you made any other changes on your network?
