jasonchu's avatar
jasonchu
Follower
Jul 21, 2022
Netgear RN102 - power light keep flashing after firmware update and Raidar status is TFTP_REQ
I have the RN102 ReadyNas.  I tried upgrading the firmware from 6.10.5 to 6.10.7 and it failed.  I use the USB Recovery mode to flash the firmware to 6.10.7 and Raider reported that Firmware is now 6.10.7 but the power light just keep blinking and I cannot access the drive.  Raidar status shows: TFTP_REQ.  I just want to get access the data.  If I cannot fix the ReadyNAS, is there a way to access my data.  I setup is just a simple RAID-0 and there is one folder that is password protected (you need the username/password to access the folder).
Please help!!  All my important files are in the NAS and I do not have a backup for the files.
1 Reply
  • StephenB's avatar
    One option is to connect one of the drives to a Windows PC using a USB/SATA adapter or dock.  Then use ReclaiMe to off-load the data.
    Note you can see if ReclaiMe can find the data before you pay for the software.
ProSupport for Business
