jimmy_maxout's avatar
jimmy_maxout
Netgear Stora, mystora.com
Anyone who have a solution to my Netgear Stora. I want to survive it from not working.
I accidently did a reset not remebering that mystora.com is down.
1.Can i make a user even if the cloud is down?
2.Can i root it and install linux?
All advice is good...
    • StephenB's avatar
      https://openwrt.org/toh/netgear/ms2000
       is this a solution for my problem?
      Could be.  Not a device I've ever owned.
      It is really old hardware that is quite slow by modern standards, so you're probably better off just getting something newer.  You'd need to go with another vendor, since Netgear no longer sells storage products.
      Do you have files you need to off-load?  It uses XFS formatting, so you can mount the volume on a linux PC (or off-load it with recovery software that supports XFS).
      • jimmy_maxout's avatar
        jimmy_maxout
        I have secured the files. The stora is perfect for my purpose so i want to revive it :)
  • schumaku's avatar
    schumaku
    Afraid no.
    Appears yes, see the link Sandshark​ supplied before.
      • StephenB's avatar
        jimmy_maxout wrote:
        Thanks! Where can i find the files?
        Looks like they are no longer there.  So you might be out-of-luck, unless another user here has them.
ProSupport for Business
