GrahameCoyle26
Jan 03, 2026Aspirant
NetgearNAS 102 File Recovery
Hi. I have an older NetgearNAS 102, two-bay NAS drive set up as RAID 1 with 2 x 3TB drives. I'm trying to recover some folders and files from the drives. I had snapshots set up for a while but no...
GrahameCoyle26
Jan 04, 2026Aspirant
Hi Stephen
The NAS works properly, and yes, I'm trying to recover files that were deleted. They are mostly pretty old work project files and folders that I didn't think I needed, and then surprise, some projects have been resurected.
The 102 is an older device and the hard drives are also older now, and I'm keen to recover anything I can and move it to another storage space.
Jan 04, 2026Guru - Experienced User
GrahameCoyle26 wrote:They are mostly pretty old work project files and folders that I didn't think I needed, and then surprise, some projects have been resurected.
If they were deleted a long time ago, then it is likely that the data has been overwritten (in some or most), even if the metadata structures are intact. You should begin by rebooting the NAS read-only to make sure nothing else is overwritten.
Also, you might check whatever snapshots you have left (simply turning them off doesn't delete existing ones).
There are a couple of scripts out there - among others
I haven't used them myself, and you should be careful to read the caveats in the readmes in any scripts if you try them.
- GrahameCoyle26Jan 04, 2026Aspirant
Thanks, Stephen. I'll try dipping my toe cautiously into those scripts and see how it goes. Cheers. Grahame
