claynz
Apr 04, 2025Guide
Network Access
I was able to access my RN314 ReadyNAS via any network computer but now get a message in Windows 11 "Path not found" how do I fix this?
saudade
Apr 05, 2025Apprentice
Did you just update Windows 11 to 24H2?
- StephenBApr 05, 2025Guru - Experienced User
That shouldn't create any issues with an RN314
- claynzApr 05, 2025Guide
My own PC is fine, I can access the shared folders and connect to the NAS through the UI.
But other PC's on the network can not, what I did this morning was go to start/run and type in the NAS IP address \\192.168.1.6 then enter and the hard drives starts spinning up and I get this error message
Go into the Windows Credential Manager and see if there is a NAS username/password for 192.168.1.6. If there isn't, then add it.
Also, go into the SMB settings on the NAS, and make sure that "SMB 3 Transport Encryption" is set to "Enabled". ("Required" will also work, but some older devices might fail if you use "Required").
Depending your NAS setup, that setting might be in system->settings->services->SMB. Or it might be on the Advanced SMB settings for each share.
