Michael_Oz
Feb 17, 2019Luminary
Network Performance graph - what's this? RN316
RN316 6.9.5
What unit is 'm', I'm presuming 'M' as per the scale is megabytes, maybe megabits??
Also is lower 'k' different to what is normally (industry) 'K' meaning kilobytes?
Sandshark
Feb 18, 2019Sensei
You are incorrect regarding the industry standard being upper case "K". The proper (and used here) SI abreviation for "kilo" is a lower-case "k". For "mega" it is an upper case "M" since "m" is milli.. The scale is clearly labeled "Bytes per second". So "k" is kilobytes per second and "M" is megabytes per second. There is an odd, inconsistent use of "m" vs. "M", though.
- Michael_OzFeb 18, 2019Luminary
I'm taking about the Information Technology 'industry'.
In my 30+ years K was 1024 bytes, until marketing got involved. (WDC settled that case BTW)
Historically (& here) the terms varied.
'k' is predominant in regards to bits, kbps, whereas as KB(1,2,3) is used for kilobytes, KBps is the usual term rather than kBps although this is also used.
e.g. 56K modem.
'Industry':
Microsoft, e.g. Windows file properties, size "1.63 KB (1,674 bytes)"
Linux, e.g. ls -lh bin/bash "-rwxr-xr-x 1 root root 1006K Nov 6 2016 bin/bash"
Netgear, e.g. Frontview share listing "482.6 KB"IBM, e.g z/OS
But you know what thay say is the best thing about computing standards?
There are so many to choose from, and
if you don't like any you can create your own.
