Han_Solo
Jul 12, 2012Tutor
New hard drives being added to the HCL
Hi Everyone, I wanted to let everyone that we have added the following new family of drives to the HCL. WD RED family of drives: Capacities of 3TB, 2TB and 1TB are now qualified on most systems,...
Jul 13, 2012Guru - Experienced User
There is also 4K sector alignment which is needed for best performance. Support for this was added in 4.1.7, so if your most recent factory default was done with an earlier release you won't have that. The drives will work, but performance will be slower.
PapaBear wrote: btaroli - the only limitations that I am aware of is that to create or expand to a volume greater than 2TB, you need to establish the array on Radiator version 4.1.0 or higher as you need the 16K blocks. This means that those with older NV and NV+ units that came with version 3 must perform a factory default on version 4 in order to use 16K blocks. This does not apply to the Duo as it never shipped with version 3.
This is found in the notes about what is new in version 4 when it was released.
With the larger drives, there is also the 8 TB expansion threshold from the initial volume size, and inability to expand beyond 16 TB - both of which need a factory default to overcome. They don't apply to the V1 models so it won't impact btaroli's friend. But of course people have run into them with the newer models that support > 2 TB drives.
