Bongo50000
Aug 11, 2016Aspirant
New Harddrive
HI Can i put a SATAIII in this NAS (ReadyNas Duo 2110 V1). I mean will it by it self go down to a SATAII. WD Red 1TB 3.5" NAS HDD SATA 6GB/s (SATA 3.0), 64MB, 24x7 reliability, IntelliPower, N...
- Aug 11, 2016
Yes. I use a WD20EFRX in my own duo v1.
mdgm-ntgr
Aug 11, 2016NETGEAR Employee Retired
If I recall correctly the port might even be SATA I.
2TB disks are the max capacity disks that will work with your NAS.
Aug 12, 2016Guru - Experienced User
Yes, that's my recollection too. But the important thing is that the WD10EFRX and the WD20EFRX both work.
BTW, even SATA I delivers 150 MB/sec, so it isn't a big limitation in the v1 products. The duo v1 is limited by its CPU (or sometimes network), not the disk speeds.
