bob_m10
Jul 03, 2017Aspirant
New NAS (Copy config and data old to new)
Hi I recently purchased a new ReadyNas 314 to replace my current 314 to allow for more disk space. I would like to swap the units and use the current until as a backup. Do these steps make sens...
- Jul 03, 2017
Don't assume that restoring the configuration will restore all the settings - so I suggest at least checking the critial settings manually. Volume maintenance is one that I know isn't restored.
Also, if you have apps installed on the existing NAS, install them on the new one before you restore the config.
Jul 03, 2017Guru - Experienced User
TeknoJnky
Jul 03, 2017Hero
I know that I may be different than others, but I usually rather start with a clean nas and reconfigure everything as needed instead of trying to import a config that you have to go back through and double check everything anyway.
BTW, the easiest thing to do would simply move your old disks to the new nas, if you want to keep everything exactly intact.
Then you can configure the old nas with a clean install and use as a backup or whatever purpose you wanted.
- StephenBJul 04, 2017Guru - Experienced User
I generally do that also.
I think that if you have a lot of users then the import is needed. But I don't.
- bob_m10Jul 05, 2017Aspirant
I have a simple setup with 2 shares so I am fine reconfiguring, The one problem is all the passwords for about 20 users which I don;t have. Perhaps I only import the usernames? Seems like that is a possibility? Bob
- StephenBJul 05, 2017Guru - Experienced User
That works, or you just upload the config file, and then review the settings.
Sometimes I've made screen snapshots first, just in case I forget how it was set up. Though the config files are readable.
