jlmacd
Apr 14, 2012Aspirant
New ReadyNAS Duo v2 and wndr3800 FW .32
I recently bought a new Duo v.2 and have populated it with 2x 2TB Samsung F4 spinpoint drives (as shown on HCL). So far I have gone no further, since reading the horror stories relating to drive failu...
Apr 14, 2012Guru - Experienced User
You have misread the situation. The WNDR3800 cannot cannot the drives inside the DUO v2.
jlmacd wrote: I recently bought a new Duo v.2 and have populated it with 2x 2TB Samsung F4 spinpoint drives (as shown on HCL). So far I have gone no further, since reading the horror stories relating to drive failures with drives attached to WNDR3800 with updated firmware to latest version (.32). I have just bought and installed a wndr3800 and duly upgraded the FW to the latest version (mostly in an effort to hopefully overcome the much reported connection dropout issues - which, touch wood, have not occurred yet!). However, I am now extremely wary of hooking the ReadyNAS up to the 3800 as, obviously, I do not want to risk damage to two brand new (and, these days, bloomin' costly!) drives.
I may have misread this situation (it could have been just referring to attached usb drives in ReadyShare mode) but, understandably, am feeling a bit cautious. Any help or insight to this would be much appreciated.
Also according to the forum reports (http://forum1.netgear.com/showthread.php?t=75322) the WNDR3800 firmware bug results in incorrectly written files (data corruption), not actual damage to the USB drives themselves. If you plan to connect USB drives to your router, you should probably downgrade its firmware to .24 - you can download the older firmware here: http://support.netgear.com/app/products ... a_id/18163 If you have no such plans, you can simply leave it at .32
