dschwartzer
Mar 31, 2016Luminary
New RN202 with a Mac Questions
I am just setting up a new ReadyNAS 202 and am having several issues. I have set up the admin account and also set myself up as a separate account as a "User" so I can interact from my Mac as a r...
- Apr 01, 2016
Hi dschwartzer,
Sorry for getting you confused, I meant "no it is NOT needed to create local users if you are not planning to have any permissions to the shares"
JennC
Apr 05, 2016NETGEAR Employee Retired
Hello dschwartzer,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
dschwartzer
Apr 05, 2016Luminary
Jenn:
Thanks for your note. I honestly believe I have bothered you enough with this issue. You have ben very helpful and I think at this point I just need to experiment a bit to see if I can make this work. This may be something the team at Netgear wants to look at in the future to see if there is a way for a user to have only one ID for both local and ReadyCloud access.
David
- JennCApr 05, 2016NETGEAR Employee Retired
Hello dschwartzer,
I understand and thanks for responding and patience. :)
If you have any suggestions or ideas as a feature or functionalities of ReadyNAS units, feel free to post at the Idea Exchange board as this board will be reviewed by developers.
- Mar 26, 2017Retired_Member
