ThomasMiller
Mar 07, 2018Aspirant
New RN316 - Network Access is SLOW
Hi! I've been doing a lot of reading on the community forums about slow network performance when accessing shares via Windows Explorer and I'm experiencing the same thing. I've checked most of the ...
Mar 07, 2018Guru - Experienced User
ThomasMiller wrote:File transfer speeds are decent, running on average at 10 Mbps both ways.
That's actually very slow. Can you try a test with NAStester? http://www.808.dk/?code-csharp-nas-performance
Test it using wired ethernet, not wifi.
- ThomasMillerMar 08, 2018Aspirant
StephenB, thank you once again for responding to my request. I stayed up a bit last night to do some troubleshooting of the issue and I started to notice that it was not just network shares that were slow to pull up documents, but also ones I had on my desktop. I redirect folders on my desktop to the NAS instead of having all the files and folders stored locally, I like to keep them on the NAS for safe keeping. When I first setup the box, it grabbed a DHCP address and I had configured the redirects with that address. This was causing the slowness when opening files, so I believe I have resolved my issue.
Thank you!
- StephenBMar 08, 2018Guru - Experienced User
I'm glad you resolved it :smileyhappy:
