janpeter1
Feb 06, 2021Luminary
New USB external disk WD 8 TB does not connect
Hello, I have a 5 year old RND314 thajt works well and I have just bought a new WD My Book 8 TD external disk for backkup. Previousl I have WD 4 TB. The new externa disk I have tested with my Ma...
- Feb 06, 2021
The problem is that the NAS doesn't support exfat. https://kb.netgear.com/7009/ReadyNAS-OS-6-USB-Port-use
NTFS is the best option if you use a PC. Though I think with a Mac, you'd either need access to a Windows system, or get a third-party package that will let you do the formatting on a Mac.
schumaku
Feb 06, 2021Guru - Experienced User
janpeter1 wrote:When the external USB disk is connected it actually blocks the start-up. Never comes "booting" in the small window of the NAS. What can be wrong?
These disks comes with various additional software on a dedicated bootable partition - which is bootable on industry standard x86 based systems what the RN are under the hood. To my knowledge, the ReadyNAS should boot from the external USB only using a defined process for recovery - and even a non-recognized file system should not cause this. StephenB any insight on this?
