jbuchal
Jan 29, 2021Tutor
Newbie Networking Problem
I was using my RN202 just fine, including access through ReadyCloud, inside a network where it had an IP address of 192.168.0.x. Our lease terminated and I had to move it to a new network that was a...
jbuchal
Jan 29, 2021Tutor
Thank you for your quick response. I was under the impression that I had set some sort of static IP in the device, but it was a long time ago and since I can't ping it, you may probably correct and it has picked up a new DCHP-supplied IP address in 192.168.1.x.
As for "talking to the network admin to make a reservation for the RN202 MAC<->IP pair, so it will keep the same IP address on the new network," there isn't one, so I have to figure this out.
The problem is, I have enabled those two services you mention, and I still can't see the Properties (Eigenshaften) for the NAS box; I get the picture below, and the Properties button is greyed out if I highlight the READYNAS box. There is no '"Storage Device" to click on to get into the admin interface; whatever I cleck on ("READYNAS") just sends me into the folders on the box. So I still can't figure out what IP address it is using and have no way to get into the admin interface.
Sandshark
Jan 30, 2021Sensei
RAIDar is, of course, the method Netgear recommends you use to find and connect to the NAS admin interface. https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar .
You are probably still going to want to reserve an address for the NAS since Windows can have issues when you use the NAS name that are alleviated when you use the IP address. That is recommended over a static IP for exactly the thing you are currently facing -- when changes are made to the network IP structure. If you had used a static IP for your NAS before, you'd still not be able to connect to it by that old IP address because it and your computer would be in different subnets and it would take even more to get around that than you are now facing.
