norm470
Jan 06, 2012Aspirant
Newbie Question on readynas Remote
Can I use readynas remote to stream movies from the nas to my tv from another location.? Thanks for your time.
mdgm-ntgr
Jan 06, 2012NETGEAR Employee Retired
Would recommend you buy a x86 ReadyNAS (e.g. Ultra, Pro). There is a Skifta add-on (http://www.skifta.com/support/readynas) designed to shift ReadyDLNA so that you can watch it at another location.
