robkwil61's avatar
Jan 08, 2025
No Access to Frontview
So my problem started about a month ago.  I had 2 hard drives failing in my NAS.  I have replaced both drives, did a factory reset on the NV+ and now I can't access Frontview.  I have read and follow...
  • robkwil61's avatar
    Jan 08, 2025
    I guess we can disregard.  I was finally able to access Frontview from my Windows 7 using IE.  But it took like 10 minutes to access the admin login and then I was able to install SSH and modify the Virtual.conf file.
ProSupport for Business
