AndyP-CH
Feb 11, 2022Aspirant
Power failure, Synchronisation, Ping success, Frontview not accessible
Hello all,
after a power failure, I'm restart the NAS and I got at the RAIDar the information for "check filesystem 0% to 100%".
At the "check filesystem 100%" it stay there for a while, about 3 minutes, then RAIDar lost the connection to the NAS.
There I received an eMail from my ReadyNas Duo with the Information within the correct Date and time for the RAID is Synchronize Drive C. ... great!
I'm able to ping the ReadyNas Duo successfully
FW V.4.1.16
Used HDD Space about 1.3 TB X-RAID
SSH not activated
Can you tell me; how long it will take to Synchronize my 1.3 TB NAS?
Until now I'm wating since about 45 hours for success.
The blue Power LED at the ReadyNAS is blinking regularly 2 x per second and the LED for Drive # 1 is flikering all the time as well. The LED for Drive # 2 is illuminated steady, I guess.
Can anybody also tell me, is it normal that I'm not able to run Frontview at that state?
The browsers tell's me always that my request is rejected ... from Win 10 = IE / Edge / Firefox / Chrome / Opera and iPhone7 = Safari / Firefox / Edge as well? Before I was running on Win 10 = IE and on iPhone = 7 Safari successfully.
Many thanks if anybody can send me your quick answer.
Kind Regards
Andy
Thx for posting the performance comparison.
AndyP-CH wrote:
Our Chat, I'll terminate it as "Problem solved". You agree?
Yes - you can always start another one if new issues arise.
AndyP-CH wrote:
Once again, I like to say thank you for your great and efficient Support.
I'm appreciate it a lot. You was a great help for me.
Thank you very much!
I'm glad I could help.
Are you able to access your shares using finder or file explorer?
Also, what connection error are you getting in the web browsers? Many (perhaps all) have just rolled out an update that drops support for TLS 1.0. Those versions can't connect to 4.1.x NAS.
If that's the situation, you could try internet explorer on a windows PC, or getting the old version of firefox (94.0.2). If you go with firefox, make sure you disable automatic updates.
https://support.mozilla.org/en-US/kb/install-older-version-firefox
- AndyP-CHAspirant
Hi Stephen
Thanksf for your reply!
I got a Win 10 Update and an edge update some days before. After that I was not able to run Frontview within Edge.
But within IE I was able to run Frontview.
But thtat´s not I'm asking fore.
I'm asking for:
And can you tell me; Is it normal that I'm not able to run Frontview at synchronisatiuon state?
Many thanks for your help!
Kind regards
Andy
45 hours is much longer than it should take.
It's not unusual for it to be non-responsive for a little while, but again, it shouldn't be unreachable for days.
