AndyP-CH
Feb 11, 2022Aspirant
Power failure, Synchronisation, Ping success, Frontview not accessible
Hello all, after a power failure, I'm restart the NAS and I got at the RAIDar the information for "check filesystem 0% to 100%". At the "check filesystem 100%" it stay there for a while, about 3 mi...
- Feb 22, 2022
Thx for posting the performance comparison.
AndyP-CH wrote:
Our Chat, I'll terminate it as "Problem solved". You agree?
Yes - you can always start another one if new issues arise.
AndyP-CH wrote:
Once again, I like to say thank you for your great and efficient Support.
I'm appreciate it a lot. You was a great help for me.
Thank you very much!
I'm glad I could help.
AndyP-CH
Feb 22, 2022Aspirant
Hi Stephen
On Saturday, I was able to set my ReadyNas Duo to factory default.
Everything was running fine, and it's running fine.
I'm not fully finish to copy all the datas back to it now.
I think ... I got a little bit more performance with the new Drives.
It's my guess ...
Networkperformance (max. values):
read write
Seagate BarraCuda green 21 MB/s 12 MB/s
Seagate IronWolf 32 MB/s 18.2 MB/s
If I can do something for you, please let me know.
Kind regards
Andy
within
Feb 22, 2022Guru - Experienced User
