robkwil61's avatar
Jan 08, 2025
No Access to Frontview
So my problem started about a month ago.  I had 2 hard drives failing in my NAS.  I have replaced both drives, did a factory reset on the NV+ and now I can't access Frontview.  I have read and followed every article I could find.  It's obviously a permissions/security issue.
I have tried several browsers (Chrome/Edge/Firefox both 32 and 64 bit versions).  I've tried on Windows 10 & 11.  I've set TLS versioning to 1.0 in Firefox.  Obviously SSL is not installed and I know of no way to install it remotely.  I even tried Windows 7 with IE.
There has to be some way to access this device but I sure can't figure it out.
Thanks!
  • I guess we can disregard.  I was finally able to access Frontview from my Windows 7 using IE.  But it took like 10 minutes to access the admin login and then I was able to install SSH and modify the Virtual.conf file.
    • robkwil61's avatar
      robkwil61
      Tutor
      Now the only issue I have is I can't seem to map the admin share and I have also noticed that my DUO and both NV+ units are not showing up in Exporer/Network Neighborhood or whatever it's called these days.
      • StephenB's avatar
        What error are you getting?  Is it possible that the PC is already accessing the NAS with other credentials?
ProSupport for Business
