robkwil61
Jan 08, 2025Tutor
No Access to Frontview
So my problem started about a month ago. I had 2 hard drives failing in my NAS. I have replaced both drives, did a factory reset on the NV+ and now I can't access Frontview. I have read and follow...
- Jan 08, 2025
I guess we can disregard. I was finally able to access Frontview from my Windows 7 using IE. But it took like 10 minutes to access the admin login and then I was able to install SSH and modify the Virtual.conf file.
robkwil61
Jan 08, 2025Tutor
robkwil61
Jan 08, 2025Tutor
Now the only issue I have is I can't seem to map the admin share and I have also noticed that my DUO and both NV+ units are not showing up in Exporer/Network Neighborhood or whatever it's called these days.
- StephenBJan 09, 2025Guru - Experienced User
What error are you getting? Is it possible that the PC is already accessing the NAS with other credentials?
- SandsharkJan 09, 2025Sensei
When you say you "can't access Frontview", what error message are you getting?
Is your antivirus by chance Norton 360?
- robkwil61Jan 09, 2025Tutor
Generally I was getting Connection Refused. But I've resolved the issue now. I was not using Norton 360.
Basically it was network location not found or something similar. I rebooted the NAS, and then my laptop and now it seems to be mapping fine. Just glad I have a Win 7 laptop and IE to be able to get into FrontView.
