AndyP-CH
Feb 11, 2022Aspirant
Power failure, Synchronisation, Ping success, Frontview not accessible
Hello all, after a power failure, I'm restart the NAS and I got at the RAIDar the information for "check filesystem 0% to 100%". At the "check filesystem 100%" it stay there for a while, about 3 mi...
- Feb 22, 2022
Thx for posting the performance comparison.
AndyP-CH wrote:
Our Chat, I'll terminate it as "Problem solved". You agree?
Yes - you can always start another one if new issues arise.
AndyP-CH wrote:
Once again, I like to say thank you for your great and efficient Support.
I'm appreciate it a lot. You was a great help for me.
Thank you very much!
I'm glad I could help.
Feb 11, 2022Guru - Experienced User
Are you able to access your shares using finder or file explorer?
Also, what connection error are you getting in the web browsers? Many (perhaps all) have just rolled out an update that drops support for TLS 1.0. Those versions can't connect to 4.1.x NAS.
If that's the situation, you could try internet explorer on a windows PC, or getting the old version of firefox (94.0.2). If you go with firefox, make sure you disable automatic updates.
https://support.mozilla.org/en-US/kb/install-older-version-firefox
AndyP-CH
Hi Stephen
Thanksf for your reply!
I got a Win 10 Update and an edge update some days before. After that I was not able to run Frontview within Edge.
But within IE I was able to run Frontview.
But thtat´s not I'm asking fore.
I'm asking for:
Can you tell me; how long it will take to Synchronize my 1.3 TB NAS?
Until now I'm wating since about 45 hours for success.
The blue Power LED at the ReadyNAS is blinking regularly 2 x per second and the LED for Drive # 1 is flikering all the time as well. The LED for Drive # 2 is illuminated steady, I guess.
And can you tell me; Is it normal that I'm not able to run Frontview at synchronisatiuon state?
Many thanks for your help!
Kind regards
Andy
- StephenBFeb 11, 2022Guru - Experienced User
45 hours is much longer than it should take.
It's not unusual for it to be non-responsive for a little while, but again, it shouldn't be unreachable for days.
- AndyP-CHFeb 12, 2022Aspirant
Hi Stephen
thanks for your reply.
I've still no access within frontview to the nas and RAIDar do not recognize it as well.
And I'm able to ping it and the nas-address give me the answer.
Antwort von 192.168.1.44: Bytes=32 Zeit<1ms TTL=64
At cmd I run:
net use \\192.168.1.44 /user:192.168.1.44\admin *Password*
I got the result:
Systemfehler 67 aufgetreten
Der Netzwerkname wurde nicht gefunden
As I'm disconnect the ethernet cable from the nas, the Disk activity LED is blinking 4 x.
As I'm reconnect the ethernet cable to the nas, the Disk activity LED is blinking 4 x also.
And the router show the NAS with the IP:192.168.1.44 again.
And here nothing has changed also.
Until now I'm wating since about 60 hours for success.
The blue Power LED at the ReadyNAS is blinking regularly 2 x per second and the LED for Drive # 1 is flikering all the time as well. The LED for Drive # 2 is illuminated steady.
I like to wait another 48 hours for the success ... wait and see ...
If this not comming to a success, what can we do?
Do you have an idea?
Regards
Andy
- StephenBFeb 12, 2022Guru - Experienced User
AndyP-CH wrote:
At cmd I run:
Try net use \\192.168.144\C /user:admin nas-admin-password
One option is to try to boot the system with disk 1 removed (power down before removing the disk).
If that also doesn't work, you can try booting with disk 2 removed (again, power down before you manipulate the disks).
Perhaps label them by slot as you remove them, so there's no chance of mixing them up.
