skmax
May 19, 2020Aspirant
No boot only telnet with USB recovery
Dear all, I am writing to ask you for advice, as a last resort, before throwing away my nas. It is a 2-Bay RN102 - ReadyNAS 100, that does not start. It is not reachable from RAIDAR. I have attemp...
skmax
May 21, 2020Aspirant
The only way Raidar sees the device is as follows:
1) I prepare a usb memory pen recovery and put it in the front usb socket
2) Food in NAS by holding down the backup button
3) USB is active (its light turns on)
4) Release the Backup button
5) When the Memory Pen stops flashing, that is, it has finished loading, I try with Raidar and the NAS can be reached in TELNET technical mode (see image)
This regardless of whether there are inserted discs that are not there.
I have not tried if the disks have problems with the appropriate tools, I will, but I don't think that's the problem.
I think that with appropriate TELNET commands we can recover. Thanks
May 21, 2020Guru - Experienced User
Were you running 6.2.4 before you did the USB recovery? It not, it was a bad idea to go back that far.
The bad serial number suggests that is damage to the flash that needs to repaired. Maybe PM JohnCM_S or Marc_V and see if they are willing to take a look.
