Gandalf9114
Mar 25, 2015Aspirant
No LED for OS6
Hi all. Back in 2007 when I got my Duo i found a great little plug in called No Led. It allowed you to either dim or turn off the very bright blue LEDs on the Duo. https://www.readynas.com/forum/v...
RX
Mar 25, 2015Luminary
It seems that there is no "No LED" App avaialble for OS 6 as of now: http://apps.readynas.com/pages/?page_id=9
However, you may open an online case with Netgear Support: https://my.netgear.com/registration/login.aspx -- then raise your concern as feature request for it to be given attention. :)
