PhotoJoseph
Jul 23, 2020Tutor
No SFTP in ReadyNAS 2312; best public server alternative?
I've set up a new ReadyNAS 2312 primarily as a local backup destination but now that it's in place I'm thinking of other uses for it. I regularly transfer multi-GB files to individuals, and have...
- Jul 24, 2020
The NAS is not set up for individual file or folder permissions, you'll need one or more shares for sharing. And you'll also have to poke a hole in your router firewall.
ReadyCLOUD may be an answer, but I recommend you also look at OwnCloud or NextCloud rather than use the NAS authentication system for occasional guest users. That's what they were built for (though they've been expanded to do much more over time) You can get a ReadyNAS ready version of either at https://rnxtras.com/ for a very reasonable fee.
I use OwnCloud myself. NextCloud was in the very early stages when I implemented it, and I just stuck with what I know. I'd probably choose NextCloud today if starting fresh.
Do you have a static public IP address and/or domain name? One of the issues you may have is installing an SSL certificate so that the user doesn't get that same warning about the site being unsafe that you do. That might turn customers away. And a domain name (which can be via dynamic IP, but is easier with static) is required for installing the certificate. ReadyCloud does avoid that part of the process as well as the poking a hole in the firewall.
