holmquistmagnus's avatar
Jul 19, 2026
No video, but good audio, in Live Viewer, readynas surveillance Toolkit.
hello
I still use readynas surveillance with my 524x and 4x4tb disks. I have 11 cameras and the toolkit has been working fine on my windows10 rig. I still think it is a very good program.
I recently bought a better pc. intel i9, rtx 3080, M.2 samsung 980. etc. It runs with windows 11.
I have been wanting to upgrade to w11 for some time.
Now, of course, the surveillance toolkit dont work.
Therefore i have installed a virtualbox with windows 7. I have installed the plugin for IE. i have isntalled C++ and Java.
In Live viewer i get good audio but no video? anyone now why?
And the Playback system starts but i get a red square that says fault and it wont work.
Has anyone managed to run readynas Surveillance Toolkit on a Windows 11 rig?
Best regards to you all.
Magnus from Sweden
  • Hello
    I can answer my own question.
    I started a windows 10 virtual mashine instead of windows 7.
    Installed Java and C++
    The toolkit works fine on  this virtual mashine. I can use live viewer and playback system with no problems.
    All this under windows 11
    Thanks for your time
    reg
    Magnus
  • Hello
    reg
    Magnus
ProSupport for Business
