emma_brad2000
Dec 02, 2022Aspirant
No Volume
Readynas Drive is showing no Volume and now i'm unable to access my data. RN104 – ReadyNAS 100 Series 4- Bay Is there a recovery method?
Dec 03, 2022Guru - Experienced User
- No volume? Or an inactive volume?
- Have you downloaded the log zip file?
- Do you have any idea of what might have caused this (disk failure, unexpected power cut, forcible shutdown of the NAS, etc)?
- emma_brad2000Dec 03, 2022Aspirant
Disk failure, i tried to replace the failed disk and then it was showing no volume.
disk 1 is the new disk, i've tried different options but unable to see any shares.
- StephenBDec 03, 2022Guru - Experienced User
It is actually showing an inactive volume (at the top of the page).
- Looks like the failed disk was disk 2 - is that correct?
- Was the volume showing a degraded status when you replaced the disk?
- Also, did you hot-swap the disk, or do something else?
Disk 1, yes degraded status, hot swap
But I think my efforts to repair have to helped.
Can I recreated the Raid? The 4 drives were running in Raid5. Have I lost everything?
