emma_brad2000
Dec 02, 2022Aspirant
No Volume
Readynas Drive is showing no Volume and now i'm unable to access my data. RN104 – ReadyNAS 100 Series 4- Bay Is there a recovery method?
emma_brad2000
Dec 03, 2022Aspirant
Disk failure, i tried to replace the failed disk and then it was showing no volume.
disk 1 is the new disk, i've tried different options but unable to see any shares.
Dec 03, 2022Guru - Experienced User
It is actually showing an inactive volume (at the top of the page).
- Looks like the failed disk was disk 2 - is that correct?
- Was the volume showing a degraded status when you replaced the disk?
- Also, did you hot-swap the disk, or do something else?
- emma_brad2000Dec 03, 2022Aspirant
Disk 1, yes degraded status, hot swap
But I think my efforts to repair have to helped.
Can I recreated the Raid? The 4 drives were running in Raid5. Have I lost everything?
- StephenBDec 03, 2022Guru - Experienced User
Maybe. FWIW, RAID (while convenient) isn't enough to keep data safe, you need a solid backup plan to do that.
Thanks. Try powering down the NAS, and removing disk 1. Then power up, and see if you still see the inactive volume (or if the degraded volume comes back).
If it does come back, then I suggest backing up data (at least the critical files) before proceeding any further.
I haven't had any luck with that but I'll try again.
any other suggestions?
Didn't work
