robertsturm
Sep 19, 2022Aspirant
No web UI radynas 102
Hello, I am having the issue to setup my readynas 102 device. My original HDD failed beyond repair. I installed new 2 TB HDD and after trying to login with default admin password I got index of admi...
Sandshark
Sep 19, 2022Sensei
That's what you see when you use HTTP instead of HTTPS. What browser are you using? The NAS will show up as "not secure" via HTTPS because of the self-signed SSL certificate, and you need to click through a warning about it, unless you aren't getting that warning and the browser is automatically changing to HTTP instead. You may need to change a security setting in your browser or change the browser you are using so it asks you what to do instead of automatically switching to HPPT.
- robertsturmSep 20, 2022Aspirant
Hi,
thank you for the answer. I am using chrome. I typed https://192.168.xxx.xxx
I got the message do you want to proceed and I have to click on advance button after that it asked for the login. I entered admin as user name and password for password.
I also tried Edge and newly installed firefox. They are all giving same result. Is there any port I have to manually go?
Thank you again.
Robert
- StephenBSep 20, 2022Guru - Experienced User
robertsturm wrote:thank you for the answer. I am using chrome. I typed https://192.168.xxx.xxx
Does https://192.168.x.x/admin behave differently?
You might need to do an OS reinstall.
- robertsturmSep 21, 2022Aspirant
Hello,
I mange to get my RN102 working. I clean the HDD and did the USB reboot with 6.10.5 Hotfix 1 firmware. After the process was finished I was able to login to Admin UI and setup the nas.
Thank you
