ColonelPanik
Dec 14, 2011Aspirant
Not a good start with the Duo V2
First I notice no product found in the support area on Netgear's site. Then I notice no screws included in the packaging for my brand new NAS. I figured Netgear would overnight me some like other comp...
mdgm-ntgr
Dec 14, 2011NETGEAR Employee Retired
Whether EXT3/EXT4 is supported or not one would think it should work. After all they're native Linux filesystems used by the ReadyNAS for the partitions on the internal disks.
Having said that using the NTFS filesystem on external disks should be fine.
