ColonelPanik
Dec 14, 2011Aspirant
Not a good start with the Duo V2
First I notice no product found in the support area on Netgear's site. Then I notice no screws included in the packaging for my brand new NAS. I figured Netgear would overnight me some like other comp...
ColonelPanik
mdgm wrote: Whether EXT3/EXT4 is supported or not one would think it should work. After all they're native Linux filesystems used by the ReadyNAS for the partitions on the internal disks.
Having said that using the NTFS filesystem on external disks should be fine.
I wasn't sure if other filesystems would break some weird software dependency. I'm new to ReadyNAS so I'm still not up to speed on how everything is setup. I've only read this is a custom Debian system.
