ashishkot
Jan 24, 2024Aspirant
not able to access RN 102 Nasbox
Accidentally my ReadyNas 102 DHCP is disable and now i am not able to access my hard drive / nasbox. I tired to reset the nasbox but not able to do that. all light are showing blue and nothing happ...
Sandshark
Jan 24, 2024Sensei
How did you "try to reset" it? What you need to do is an OS re-install. That will re-establish DHCP and also reset the admin password to password.
Alternately, connect a PC directly to the ethernet port of the NAS and manually set the IP address of the PC to one in the same subnet as the NAS. Then, use the GUI to re-enable DHCP.
