junpit2
Jan 27, 2020Aspirant
Not sure what this RNDU4000 is
Hi
Just bought a RNDU4000 off ebay for setting up a new nas at home. I've been working in IT for over 20 years and I'm a bit surprised about this unit. I was expecting it to be different. The web interface looks very different and the device doesnt seem to be running when expected. No add ons or ability to install any etc. message.log says SunOS on boot.
I logged into it using a admin/password when I expected it to be admin/netgear1 and the device says its a readydata 3.04. It wanted a firmware update. Its now runing firmware 1.4.5. Any advice please.
-Darren
It sounds like someone managed to load the ReadyData firmware onto the Ultra-4. There is a software manual here: http://www.downloads.netgear.com/files/GDC/RD5200/ReadyDATA_OS_SW_UM-09.pdf
It is running the current firmware.
Netgear won't provide support for used equipment. But I think Sandshark might have gotten OS-6 to run on a real ReadyData platform, and he might be able to help you convert the Ultra again to run OS 6 firmware.
- mdgmVirtuoso
Sounds like you picked up a unit from a beta test from a long while back where testers were provided Ultra 4 units running ReadyDATA OS.
The EEPROM would have been wiped by the conversion to run ReadyDATA OS.
USB Boot Recovery + manually fixing the EEPROM would get it back up and running properly on RAIDiator-x86 or ReadyNAS OS 6.- junpit2AspirantOk. I’m going to stop there I think. The seller clearly didn’t realise. It was a recovery company.
There were only 2 drive trays and they’re both missing the plastic inserts so I’m sending it back. I was looking for something to host 15TB of storage (3x5)on the cheap.
Apart from something new, what should I be on the lookout for. Should I get another RNDU4000 which I can take up to OS6? I nearly bought a RND4210 but didn’t like the spec.
Thanks
Darren- StephenBGuru - Experienced User
junpit2 wrote:
Ok. I’m going to stop there I think. The seller clearly didn’t realise. It was a recovery company. ... There were only 2 drive trays and they’re both missing the plastic inserts so I’m sending it back.Logical. The drive trays actually aren't that easy to track down.
FWIW, the old NAS models didn't have the plastic inserts. They were introduced with OS-6 NAS.
junpit2 wrote:
Apart from something new, what should I be on the lookout for. Should I get another RNDU4000 which I can take up to OS6? I nearly bought a RND4210 but didn’t like the spec.The RND4210 can't be converted to OS-6. In addition to low performance by modern standards, it is limited to SMB 1. My own is still running, but only as a secondary backup. Though they were well built, I wouldn't purchase one now.
Desktop models that can be converted include the Pro, Ultra Plus, and Ultra. You can't convert the NVX - it has a 32 bit architecture and you need 64 bits. If you are planning to upgrade the memory or the CPU, the Pro/Ultra Plus are the best options.
The Pro and the Ultra Plus have the same hardware specs. There was an older Pro line (Pioneer and Business Edition) which had a somewhat less powerful CPU - you can tell them apart by the part number. The final Pro line ends in -200XXX, the older models end in -100XXX.
You might also find some used OS6 NAS - for instance the RN516 or the RN314. If you are interested in the ARM-based system, you could go with the RN214. I'd avoid the RN104.
