LaceyDad
Feb 14, 2023Aspirant
NS 104, how to back up a second PC disk
C: works for years, a user has to be moved off to recover C: space Added đ§ and can not get NAS BACK UP to find drive. All other C: drive work What to try?
LaceyDad
Feb 15, 2023Aspirant
First, THANKS to ALL, I finally figured it out, I was entering the absolute path, where the firmware knew that, so when I entered the correct syntax, the system filled in the blanks. Unfortunately the manual does not tell you this, but for the most part it was easy to set up. It has been running for 7 years, without an issues. I need to move a user off, AV processing, to a separate device, I used a M.2 memory in a ESATA enclosure, to a SATA connector on the mother board, no real-estate in case. I ran a scheduled back up and all users on both drives were copied. Hopefully this will help someone else. Best regards Lacey Dad
