Infinite
Nov 14, 2009Aspirant
NUT on OSX 10.6 [Sharing a UPS with ReadyNAS and Computers]
First off: I can not take much credit for this post, the majority of this write up was done by Egg in this post "NUT on OS X (10.5.7)" which was priceless in my effort to get this matter solved. It ...
Pian
Jan 16, 2010Aspirant
One thing to note from the FinkCommander FAQ ( http://finkcommander.sourceforge.net/help/faq.php Q2 ) is that under Snow Leopard you have to change the path of perl:
"You are on Snow Leopard (OS 10.6) and haven't set FinkCommander to use Perl 5.8.9. You can easily do so in FinkCommander:Preferences:Path:Path to Perl by entering the value /usr/bin/perl5.8.9"
Also, the mac being used as a client must have XCode installed.
Otherwise, thanks for the great guide.
