nitro001's avatar
nitro001
NV+ 4.1.9 Firmware Internal Mail no longer working?
All,
Not sure if I am posting this in the right forum, probably not, and if not, please move where appropriate.
I have determined that the internal mail for the Readynas seems to be broken. I had not been receiving alerts for a while even after a restart which led me to begin some Investigating. I went into the Alert properties, set one email and did a test (ntruhan@XXXXX masked out) then set another email for a test since the first did not come through (ntruhan@YYYY) and in doing so, I found the following in the following in the /var/log/exim/mainlog
2012-09-23 00:23:02 1TEakw-0000rV-00 Message is frozen
2012-09-23 00:23:02 End queue run: pid=4637
2012-09-23 00:25:26 1TFdl0-0001EL-00 <= ntruhan@XXXXXXXX U=root P=local S=369
2012-09-23 00:25:31 1TFdl0-0001EL-00 ** ntruhan@XXXXXXXX R=lookuphost T=remote_smtp: SMTP error from remote mailer after HELO rubix: host e38.co.XXXXXXXX [32.97.110.159]: 501 Syntax error in parameters or arguments
2012-09-23 00:25:31 1TFdl5-0001Ee-00 <= <> R=1TFdl0-0001EL-00 U=mail P=local S=1236
2012-09-23 00:25:31 1TFdl0-0001EL-00 Error message sent to ntruhan@XXXXXXXX
2012-09-23 00:25:31 1TFdl0-0001EL-00 Completed
2012-09-23 00:25:33 1TFdl5-0001Ee-00 ** ntruhan@XXXXXXXX R=lookuphost T=remote_smtp: SMTP error from remote mailer after HELO rubix: host e8.ny.XXXXXXXX [32.97.182.138]: 501 Syntax error in parameters or arguments
2012-09-23 00:25:33 1TFdl5-0001Ee-00 Frozen (delivery error message)
2012-09-23 00:27:11 1TFdmh-0001Fr-00 <= ntruhan@YYYYYY U=root P=local S=363
2012-09-23 00:27:14 1TFdmh-0001Fr-00 ** ntruhan@YYYYYY R=lookuphost T=remote_smtp: SMTP error from remote mailer after RCPT TO:<ntruhan@YYYYYY>: host mail.messaging.microsoft.com [216.32.180.22]: 550 5.7.1 Service unavailable; Client host [XX.YY.ZZ.WW] blocked using Blocklist 1, mail from IP banned; To request removal from this list please forward this message to delist@messaging.microsoft.com and include your ip address XX.YY.ZZ.WW .
2012-09-23 00:27:14 1TFdmk-0001GA-00 <= <> R=1TFdmh-0001Fr-00 U=mail P=local S=1452
2012-09-23 00:27:14 1TFdmh-0001Fr-00 Error message sent to ntruhan@YYYYYY
2012-09-23 00:27:14 1TFdmh-0001Fr-00 Completed
2012-09-23 00:27:15 1TFdmk-0001GA-00 ** ntruhan@YYYYYY R=lookuphost T=remote_smtp: SMTP error from remote mailer after RCPT TO:<ntruhan@YYYYYY>: host mail.messaging.microsoft.com [216.32.180.190]: 550 5.7.1 Service unavailable; Client host [XX.YY.ZZ.WW] blocked using Blocklist 1, mail from IP banned; To request removal from this list please forward this message to delist@messaging.microsoft.com and include your ip address XX.YY.ZZ.WW .
2012-09-23 00:27:15 1TFdmk-0001GA-00 Frozen (delivery error message)
2012-09-23 00:38:02 Start queue run: pid=5202
2012-09-23 00:38:02 1Ogxdr-0003Ol-00 Message is frozen
But it seems that it is getting formatted wrong: 501 Syntax error in parameters or arguments. Then tries again and gets banned from mail.messaging.microsoft.com?
I wasn't sure if it was related to the firmware update, or the latest changes in Microsoft's mail systems, or something else, but if you change the mail system provider to something else, say the Gmail provider, which I know uses another system outside of exim, it works and sends the message which I receive and I get success logs in the /var/log/frontview/msmtp.log:
Sep 23 00:35:32 host=smtp.gmail.com tls=on auth=on user=XXXX@gmail.com from=XXXX@gmail.com recipients=ntruhan@XXXXXXX mailsize=161 exitcode=EX_OK
So for now, I will continue to use gmail, but if anyone else is having problems with Internal SMTP not sending emails, check the /var/log/exim/mainlog for syntax or rejection errors.
Nathan
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Some ISPs block the internal mail server. It is recommended to use e.g. Gmail for sending the emails.
  • It was just interesting, it worked for years, I am on my 2nd NV+. Has one the first year they came out before they were netgear, and I have been with time warner cable for almost 3 years and it just now stopped working a couple months ago.
ProSupport for Business
