holsen1
Jul 17, 2021Aspirant
NV+ Died - SAVE Info On Disks
About a year ago, I replace the power supply on my NV+ RND 4000 - Today I notice the Nas and my mapped drives were offline. Looking at the display panel, the light was dim and it showed me the used...
- Jul 26, 2021
Last Message - I Promise - Just A Confirmation of Success!
I clipped wire 12 and 18 on an extention cable and spliced them into wire 10 and everything is working perfectly!
I now have a monstrous power supply sitting outside the NAS but that's OK and the cable connector fit though the cutout for the power connector of the previous inbult power supply. It's whisper quiet and and will run much cooler!
Thanks Again
holsen1
Jul 22, 2021Aspirant
Thanks for getting back to me and sorry for my delay in responding here. I havent been able to log back in until now ..... I always have to fight with this system, it never accepts my email or password....
Anyway, I can now confirm that it's the power suply.... Another one bites the dust, but it's getting increasingly difficult to to find a replacement.
Any Idea where I can find one, or find instructions at to how to jerrt-rig one?
Thanks!
Jul 22, 2021Guru - Experienced User
Sandshark might be able to give you some guidance on how to find one.
Stock supplies do require a pinout change. If you have an ATX supply you could connect it to the NAS with a cable extender, and make the needed mods in the extender. That's not a good path for long term use, but would give you enough time to off-load the data.
The pinout change is detailed in the attached pdf.
- SandsharkJul 22, 2021Sensei
It's a modified Flex ATX (aka mini ITX) supply. The modifications are the pin-out and the cooling. StephenB provided the pin-out difference, and the cooling is modified by removing the fan, adding vents, and using an air dam. It can be tricky to find the fight supply that you can move the original cover to and disconnect the fan, and also be sure the cable is long enough. There is a UK seller on eBay that has some already modified that use a fan mounted on the opposite end, so it doesn't need to be removed and provides better cooling, but they are a tad expensive. I also see some cheaper ones, but they still have the fan in the typical location (same end as AC power cord), and it's going to be blocked when installed, I think. I did once install one without modifying the cooling by moving it back about an inch, securing it with aluminum tape. Maybe the second one I mentioned earlier is doing something like that. Frankly, it was a kludge and I wouldn't do it again if it was for an extended period of time.
Also be careful. Some sellers don't know what "Flex ATX" is and are selling supplies with a top-mounted fan under that description.
- holsen1Jul 26, 2021Aspirant
Thanks again @StephenB and Sandshark
I picked up an ATX PSU with the convertible 24 to 20 pin cable. I would just like to check one one time before I move the pins.
If I read this diagram correctly here's what I need to do:
1. Remove Blue slot 12
2. Remove White Slot18
3. Splice two wires onto Yellow 10 and insert one into 12 and the other into 18
Is that correct? or is there a better way to do this?
Thanks again.
Thanks Again
