holsen1
Jul 17, 2021Aspirant
NV+ Died - SAVE Info On Disks
About a year ago, I replace the power supply on my NV+ RND 4000 - Today I notice the Nas and my mapped drives were offline. Looking at the display panel, the light was dim and it showed me the used...
- Jul 26, 2021
Last Message - I Promise - Just A Confirmation of Success!
I clipped wire 12 and 18 on an extention cable and spliced them into wire 10 and everything is working perfectly!
I now have a monstrous power supply sitting outside the NAS but that's OK and the cable connector fit though the cutout for the power connector of the previous inbult power supply. It's whisper quiet and and will run much cooler!
Thanks Again
holsen1
Jul 26, 2021Aspirant
Thanks again @StephenB and Sandshark
I picked up an ATX PSU with the convertible 24 to 20 pin cable. I would just like to check one one time before I move the pins.
If I read this diagram correctly here's what I need to do:
1. Remove Blue slot 12
2. Remove White Slot18
3. Splice two wires onto Yellow 10 and insert one into 12 and the other into 18
Is that correct? or is there a better way to do this?
Thanks again.
holsen1
Thanks Again
- SandsharkJul 27, 2021Sensei
It's actually better and easier to use a 20/24 pin extension. Then you have two extra 12V wires from the 4-pin section removed from the NAS end to go in in place of the pins you removed. If you plan to continue to operate that way, you might want to get a new extender and wire that way. Also, for extended use, seal the area around where the cable comes in so the chassis fan doesn't draw air in through there, reducing air flow around the drives.
- holsen1Jul 27, 2021Aspirant
Great tip. I sealed up the area with duct tape and my operating temp has indeed dropped several degrees. Muchas Gracias.
