BennyKind
Apr 22, 2013Guide
NV+ freezes when adding new HDD #21013685
Hi everyone, I had a failed disk so I removed it and replaced it with another one exactly the same as the one that failed. I insert the disk and it tells me that it is initializing. That is succ...
mdgm-ntgr
Apr 22, 2013NETGEAR Employee Retired
Continue backing up your data as the first step.
What version of RAIDiator are you running?
Wat brand and model disks?
You may wish to open a tech support case (see Online Submission link in my sig) and post your case number.
- Jan 17, 2024Retired_Member
