illmatic
Nov 26, 2012Guide
[NV+ v2] 4 disks, 2 separate RAID-1 volumes?
I am about to purchase a 4-bay NV+ v2. I would like confirmation that it can support 2 separate RAID-1 volumes -- for example, disk 1 and 2 are mirrors, and 3 and 4 are mirrors. But 1-2 and 3-4 are ...
Nov 27, 2012Guru - Experienced User
I don't have a v2 but I believe you can do this if you set up the unit to use flexraid.
