illmatic
Nov 26, 2012Guide
[NV+ v2] 4 disks, 2 separate RAID-1 volumes?
I am about to purchase a 4-bay NV+ v2. I would like confirmation that it can support 2 separate RAID-1 volumes -- for example, disk 1 and 2 are mirrors, and 3 and 4 are mirrors. But 1-2 and 3-4 are ...
illmatic
Nov 27, 2012Guide
gibxxi wrote: I'm also pretty sure it can't be done the way you want
Thanks for the reply. Forget the network shares for a minute -- can it handle RAID-1 mode only, over disks 1/2 and disks 3/4 ?
