illmatic
Nov 26, 2012Guide
[NV+ v2] 4 disks, 2 separate RAID-1 volumes?
I am about to purchase a 4-bay NV+ v2. I would like confirmation that it can support 2 separate RAID-1 volumes -- for example, disk 1 and 2 are mirrors, and 3 and 4 are mirrors. But 1-2 and 3-4 are ...
Nov 27, 2012Guru - Experienced User
Yes. The manual is here: http://www.downloads.netgear.com/files/ ... 5Sep12.pdf
Read the section on flex raid (page 21-22)
You can create one shared folder on each volume, and simply map that root shared folder. So you can certainly do what you want.
