Grimleiv's avatar
Dec 04, 2017
NV+ V2 Volume expansion failed with 4x4TB WD red drives
I'm trying to set up with 4 x 4TB Segate disks. Factory reset done, disk control ok.. but volume ends up 8TB. Latest firmware installed, all looks good.    I tried just use 3x4TB, volume ended up 7...
  • bedlam1's avatar
    bedlam1
    Dec 05, 2017
    Try using this Calculator to experiment with your options
ProSupport for Business
