Grimleiv
Dec 04, 2017Tutor
NV+ V2 Volume expansion failed with 4x4TB WD red drives
I'm trying to set up with 4 x 4TB Segate disks. Factory reset done, disk control ok.. but volume ends up 8TB. Latest firmware installed, all looks good. I tried just use 3x4TB, volume ended up 7...
- Dec 05, 2017
Try using this Calculator to experiment with your options
Grimleiv
Dec 04, 2017Tutor
Atm i have 3x4TB +1x3TB syncing up, so far it report 8TB but still some hours sync. I wonder why it always sync at last drive.. So when done sync it will add the TB from last drive to the 8TB.. Even i have 3x4TB + 1x3TB = 15TB minus safty :)
This time i didnt choose the xraid, dont remember name, but i use the nr 2 option. Read somwhere here that xraid was max 8tb and that somone choosed the other option and got 12TB..
Will tell tomorrow when sync is done.. Really hoping to get 12TB out of this nv+ v2 :D
Grimleiv
Dec 04, 2017Tutor
The raid i'm testin now with 3x4TB + 1x3TB is Flex-Raid Raid 5. Will that end in 8TB also? If so, why?
:)Thanks for assist so far.
