Grimleiv
Dec 04, 2017Tutor
NV+ V2 Volume expansion failed with 4x4TB WD red drives
I'm trying to set up with 4 x 4TB Segate disks. Factory reset done, disk control ok.. but volume ends up 8TB. Latest firmware installed, all looks good. I tried just use 3x4TB, volume ended up 7...
- Dec 05, 2017
Try using this Calculator to experiment with your options
bedlam1
Dec 05, 2017Prodigy
Grimleiv
Dec 05, 2017Tutor
Nice Calkulator. That made me see whats going on :) So all is ok.. it's just the raids that dont handle different volumes.
Will go for 4x4TB then, try get most out of it with raid 5
Thanks for help :D
