punisher1991
Jan 12, 2016Aspirant
NV+V2 problems
hello all i have a few problems with my nas ( which i've had for 10+ months with no issues ) till i had a power cut and lost a drive.. which i have now replaced however when all drives are plugge...
- Jan 15, 2016
it appeared to be just locked disks issues.
thanks everyone that posted and helped :)
JennC
Jan 12, 2016NETGEAR Employee Retired
Hello punisher1991,
Welcome to the community!
I have few questions to ask:
- Do you still have access to the NAS' shares after removing the failed disk?
- How many disks are inserted?
- Do you have full backup of the files?
- What's the RAID level?
punisher1991
- BrianL2Jan 12, 2016NETGEAR Employee Retired
Hi punisher1991,
This is normal if the volume RAID used is 0. Try first to scan the failed drive using the manufacturer's diagnostic tool to see if its still clonable. Lastly, I strongly suggest that you continue to work with our support team in trying to recover your data, but expect that there'll be a fee.
Kind regards,
BrianL
NETGEAR Community Team- punisher1991Jan 12, 2016Aspirant
hello brian i've already checked the drive and it was deemed as faulty
and the data isn't that important but what is important is getting this nas server working once againas when i try to reinstall the os it just hangs on installing addons and thats as far as its gets
if i factory reinstall with all drives in ( 4 of WD Red 2Tb's ) it takes a while ( 18hours or more ) it does work but i cant gain access via webpanel
cheers- JennCJan 13, 2016NETGEAR Employee Retired
Hello punisher1991,
You mentioned it does work when you factory reinstall with all the drives but you are not able to access the admin page. Are you referring to the access of the shares when you say it does work?
If you are able to access the shares and just not able to access the admin page, have you tried other web browsers? Or another computer?
May we ask for the current firmware version of the NAS too?
