minterbrad
Aug 26, 2020Aspirant
NV+v2 repalcing a 2TB JBOD drive with 4TB builds 2TB volume
I have previously replaced 2TB JBOD drives with 3TB and 4TB in the NV+v2 without issue. Replacing a drive recently (remove /c 2TB, replace with 4TB) the new drive volume is only 2TB. It is the same...
Sandshark
Aug 30, 2020Sensei
Since each drive is a separate JBOD volume, the 8TB volume expansion limit shouldn't be coming into play, but I wonder if it is somehow. I've not done any multi-volume experiments on a V2 unit, and only have a DuoV2 on which to do so.
Via SSH, looking at the output of cat /proc/mdstat may be helpful. There may also be info in the downloaded logs .zip, which one of the Netgear Mods may help you decipher.
Since you have previously used drives >2TB, that shows you do have a real V2, so the 2TB drive size limit of the V1 is not in play.
If you do end up doing a factory reset to gain use of all drives, that should not affect the content of your USB drives.
When your message first appeared, it was locked against replies (at least from us mortals). Now that it's unlocked, maybe you'll get more.
Note to Netgear mods: The KB artical pointed to above lists hard limits for the 300, 500, and 700 series ReadyNAS that are clearly based on 4TB drives are way out of date.
- StephenBAug 30, 2020Guru - Experienced User
If they are in fact JBOD, there is no expansion happening - so this limit shouldn't be a factor.
I'd also look at partition.log.
- minterbradAug 31, 2020Aspirant
The Partition log follows. Should I reformat EXT3 to get rid of the GPT error?
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sde'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdc'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdd'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdi'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdj'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sda: 4000.8 GB, 4000787030016 bytes
255 heads, 63 sectors/track, 486401 cylinders, total 7814037168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000Device Boot Start End Blocks Id System
/dev/sda1 1 4294967295 2147483647+ ee GPTDisk /dev/sdb: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors
/dev/sdb1 1 3907029167 1953514583+ ee GPTDisk /dev/sde: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0xf74775ddDevice Boot Start End Blocks Id System
/dev/sde1 2048 3907026943 1953512448 7 HPFS/NTFSDisk /dev/sdf: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0xa58ea3d9Device Boot Start End Blocks Id System
/dev/sdf1 1985 3907022847 1953510431+ f W95 Ext'd (LBA)
/dev/sdf5 2048 3907022847 1953510400 7 HPFS/NTFSDisk /dev/sdc: 3000.6 GB, 3000592982016 bytes
255 heads, 63 sectors/track, 364801 cylinders, total 5860533168 sectors
/dev/sdc1 1 4294967295 2147483647+ ee GPTDisk /dev/sdd: 4000.8 GB, 4000787030016 bytes
/dev/sdd1 1 4294967295 2147483647+ ee GPTDisk /dev/sdg: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x9df3f892Device Boot Start End Blocks Id System
/dev/sdg1 2048 3907026943 1953512448 7 HPFS/NTFSDisk /dev/sdh: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0xd12243a0Device Boot Start End Blocks Id System
/dev/sdh1 1985 3907026943 1953512479+ f W95 Ext'd (LBA)
/dev/sdh5 2048 3907026943 1953512448 7 HPFS/NTFSDisk /dev/sdi: 4000.8 GB, 4000787030016 bytes
256 heads, 63 sectors/track, 484501 cylinders, total 7814037168 sectors
Disk identifier: 0x2d39e5a8Device Boot Start End Blocks Id System
/dev/sdi1 1 4294967295 2147483647+ ee GPTDisk /dev/sdj: 4000.8 GB, 4000787030016 bytes
WARNING: GPT (GUID Partition Table) detected on '/dev/sdk'! The util fdisk doesn't support GPT. Use GNU Parted.Disk /dev/md0 doesn't contain a valid partition table
Disk /dev/md1 doesn't contain a valid partition table
Disk /dev/md7 doesn't contain a valid partition table
Disk /dev/md6 doesn't contain a valid partition table
Disk /dev/md4 doesn't contain a valid partition table
Disk /dev/md5 doesn't contain a valid partition table
Disk /dev/dm-0 doesn't contain a valid partition table
Disk /dev/dm-1 doesn't contain a valid partition table
Disk /dev/dm-2 doesn't contain a valid partition table
Disk /dev/dm-3 doesn't contain a valid partition table
512 bytes
Disk identifier: 0x69e34743Device Boot Start End Blocks Id System
/dev/sdj1 1 4294967295 2147483647+ ee GPTDisk /dev/sdl: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x3534be60Device Boot Start End Blocks Id System
/dev/sdl1 1985 3907022847 1953510431+ f W95 Ext'd (LBA)
/dev/sdl5 2048 3907022847 1953510400 7 HPFS/NTFSDisk /dev/sdk: 2000.4 GB, 2000398934016 bytes
256 heads, 63 sectors/track, 242251 cylinders, total 3907029168 sectors
/dev/sdk1 1 4294967295 2147483647+ ee GPTDisk /dev/md0: 4293 MB, 4293906432 bytes
2 heads, 4 sectors/track, 1048317 cylinders, total 8386536 sectors
Disk /dev/md1: 536 MB, 536858624 bytes
2 heads, 4 sectors/track, 131069 cylinders, total 1048552 sectors
Disk /dev/md7: 1995.6 GB, 1995563909120 bytes
2 heads, 4 sectors/track, 487198220 cylinders, total 3897585760 sectors
I/O size (minimum/optimal): 16384 bytes / 16384 bytes
Disk /dev/md6: 1995.6 GB, 1995563909120 bytes
Disk /dev/md4: 2995.8 GB, 2995760037888 bytes
2 heads, 4 sectors/track, 731386728 cylinders, total 5851093824 sectors
Disk /dev/md5: 3996.0 GB, 3995954085888 bytes
2 heads, 4 sectors/track, 975574728 cylinders, total 7804597824 sectors
Disk /dev/dm-0: 1984.8 GB, 1984811761664 bytes
255 heads, 63 sectors/track, 241306 cylinders, total 3876585472 sectors
Disk /dev/dm-1: 1984.8 GB, 1984811761664 bytes
Disk /dev/dm-2: 3985.2 GB, 3985192779776 bytes
255 heads, 63 sectors/track, 484505 cylinders, total 7783579648 sectors
Disk /dev/dm-3: 2985.0 GB, 2985002270720 bytes
255 heads, 63 sectors/track, 362905 cylinders, total 5830082560 sectors
Disk identifier: 0x00000000 - minterbradAug 31, 2020Aspirant
StephenBhere is the partition.log. I tried formatting as GPT/EXT3 in Windows with Minitool Partition Magic and re-inserted the disk into the NV+v2...same result with a 2TB created partition. Frontview sees the drive as a 4TB, so still stumped...
/dev/sdd1 1 4294967295 2147483647+ ee GPTDisk /dev/sdh: 2000.4 GB, 2000398934016 bytes
/dev/sdh5 2048 3907026943 1953512448 7 HPFS/NTFSDisk /dev/sdg: 2000.4 GB, 2000398934016 bytes
/dev/sdg1 2048 3907026943 1953512448 7 HPFS/NTFSDisk /dev/sdi: 4000.8 GB, 4000787030016 bytes
512 bytes
/dev/sdj1 1 4294967295 2147483647+ ee GPTDisk /dev/sdk: 2000.4 GB, 2000398934016 bytes
/dev/sdk1 1 4294967295 2147483647+ ee GPTDisk /dev/sdl: 2000.4 GB, 2000398934016 bytes
/dev/sdl5 2048 3907022847 1953510400 7 HPFS/NTFSDisk /dev/md0: 4293 MB, 4293906432 bytes
Disk identifier: 0x00000000- StephenBSep 01, 2020Guru - Experienced User
Putting the pieces together for the two 4TB drives:
Disk /dev/sda: 4000.8 GB, 4000787030016 bytes 7814037168 sectors md7: 1948792880 blocks Disk /dev/sdd: 4000.8 GB, 4000787030016 bytes 7814037168 sectors md5: 3902298912 blocks
Disk sda is detected as the correct size, but the md7 is too small.
I don't know why that is though. Can you try deleting the volume, and creating it again?
Sandshark, thanks for the pointers...here is the mdstat data. Oddly, md0 and md1 show "active raid1", whereas the box is set to RAID0. I'm not sure how to read this, so input welocme here...
root@ReadyNAS2:/# cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md5 : active raid0 sdd3[0]
3902298912 blocks super 1.2 16k chunksmd4 : active raid0 sdc3[0]
2925546912 blocks super 1.2 16k chunksmd6 : active raid0 sdb3[0]
1948792880 blocks super 1.2 16k chunksmd7 : active raid0 sda3[0]
1948792880 blocks super 1.2 16k chunksmd1 : active raid1 sda2[5] sdd2[3] sdc2[2] sdb2[4]
524276 blocks super 1.2 [4/4] [UUUU]md0 : active raid1 sdc1[2] sda1[5] sdb1[4] sdd1[3]
4193268 blocks super 1.2 [4/4] [UUUU] - minterbradAug 31, 2020Aspirant
Sandshark, thanks for the feedback...please see status below:
Sandshark, thanks for the feedback. I have tried to post several times and it did not seem to show in this thread. Trying again.
Please see the disk status below:
