minterbrad
Aug 26, 2020Aspirant
NV+v2 repalcing a 2TB JBOD drive with 4TB builds 2TB volume
I have previously replaced 2TB JBOD drives with 3TB and 4TB in the NV+v2 without issue. Replacing a drive recently (remove /c 2TB, replace with 4TB) the new drive volume is only 2TB. It is the same...
Aug 30, 2020Guru - Experienced User
Sandshark wrote:
Since each drive is a separate JBOD volume, the 8TB volume expansion limit shouldn't be coming into play, but I wonder if it is somehow.
If they are in fact JBOD, there is no expansion happening - so this limit shouldn't be a factor.
I'd also look at partition.log.
minterbrad
Aug 31, 2020Aspirant
The Partition log follows. Should I reformat EXT3 to get rid of the GPT error?
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sde'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdc'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdd'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdi'! The util fdisk doesn't support GPT. Use GNU Parted.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdj'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sda: 4000.8 GB, 4000787030016 bytes
255 heads, 63 sectors/track, 486401 cylinders, total 7814037168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sda1 1 4294967295 2147483647+ ee GPT
Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors
/dev/sdb1 1 3907029167 1953514583+ ee GPT
Disk /dev/sde: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0xf74775dd
/dev/sde1 2048 3907026943 1953512448 7 HPFS/NTFS
Disk /dev/sdf: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0xa58ea3d9
/dev/sdf1 1985 3907022847 1953510431+ f W95 Ext'd (LBA)
/dev/sdf5 2048 3907022847 1953510400 7 HPFS/NTFS
Disk /dev/sdc: 3000.6 GB, 3000592982016 bytes
255 heads, 63 sectors/track, 364801 cylinders, total 5860533168 sectors
/dev/sdc1 1 4294967295 2147483647+ ee GPT
Disk /dev/sdd: 4000.8 GB, 4000787030016 bytes
/dev/sdd1 1 4294967295 2147483647+ ee GPT
Disk /dev/sdg: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x9df3f892
/dev/sdg1 2048 3907026943 1953512448 7 HPFS/NTFS
Disk /dev/sdh: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0xd12243a0
/dev/sdh1 1985 3907026943 1953512479+ f W95 Ext'd (LBA)
/dev/sdh5 2048 3907026943 1953512448 7 HPFS/NTFS
Disk /dev/sdi: 4000.8 GB, 4000787030016 bytes
256 heads, 63 sectors/track, 484501 cylinders, total 7814037168 sectors
Disk identifier: 0x2d39e5a8
/dev/sdi1 1 4294967295 2147483647+ ee GPT
Disk /dev/sdj: 4000.8 GB, 4000787030016 bytes
WARNING: GPT (GUID Partition Table) detected on '/dev/sdk'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/md0 doesn't contain a valid partition table
Disk /dev/md1 doesn't contain a valid partition table
Disk /dev/md7 doesn't contain a valid partition table
Disk /dev/md6 doesn't contain a valid partition table
Disk /dev/md4 doesn't contain a valid partition table
Disk /dev/md5 doesn't contain a valid partition table
Disk /dev/dm-0 doesn't contain a valid partition table
Disk /dev/dm-1 doesn't contain a valid partition table
Disk /dev/dm-2 doesn't contain a valid partition table
Disk /dev/dm-3 doesn't contain a valid partition table
512 bytes
Disk identifier: 0x69e34743
/dev/sdj1 1 4294967295 2147483647+ ee GPT
Disk /dev/sdl: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x3534be60
/dev/sdl1 1985 3907022847 1953510431+ f W95 Ext'd (LBA)
/dev/sdl5 2048 3907022847 1953510400 7 HPFS/NTFS
Disk /dev/sdk: 2000.4 GB, 2000398934016 bytes
256 heads, 63 sectors/track, 242251 cylinders, total 3907029168 sectors
/dev/sdk1 1 4294967295 2147483647+ ee GPT
Disk /dev/md0: 4293 MB, 4293906432 bytes
2 heads, 4 sectors/track, 1048317 cylinders, total 8386536 sectors
Disk /dev/md1: 536 MB, 536858624 bytes
2 heads, 4 sectors/track, 131069 cylinders, total 1048552 sectors
Disk /dev/md7: 1995.6 GB, 1995563909120 bytes
2 heads, 4 sectors/track, 487198220 cylinders, total 3897585760 sectors
I/O size (minimum/optimal): 16384 bytes / 16384 bytes
Disk /dev/md6: 1995.6 GB, 1995563909120 bytes
Disk /dev/md4: 2995.8 GB, 2995760037888 bytes
2 heads, 4 sectors/track, 731386728 cylinders, total 5851093824 sectors
Disk /dev/md5: 3996.0 GB, 3995954085888 bytes
2 heads, 4 sectors/track, 975574728 cylinders, total 7804597824 sectors
Disk /dev/dm-0: 1984.8 GB, 1984811761664 bytes
255 heads, 63 sectors/track, 241306 cylinders, total 3876585472 sectors
Disk /dev/dm-1: 1984.8 GB, 1984811761664 bytes
Disk /dev/dm-2: 3985.2 GB, 3985192779776 bytes
255 heads, 63 sectors/track, 484505 cylinders, total 7783579648 sectors
Disk /dev/dm-3: 2985.0 GB, 2985002270720 bytes
255 heads, 63 sectors/track, 362905 cylinders, total 5830082560 sectors
